How Did You Torque Your Driveshaft?
redsn95gt
143
Having hell of a time of finding a wrench combo that will fit the driveshaft companion flange bolts with either of my torque wrenches and still have a solid contact. Everything kinda leaves it at a nasty angle, I really don't want to strip one of these bolts. What did you use to get a good grip on those bolts?
Thanks
12mm wrench is all you need. I know there is a torque spec, but it's not a critical area. Just make sure you put plenty of loctite on them. I've never torqued them down with a torque wrench.
Kurt
Reactions: Scrapla347
If the've never been off ... the're gonna be very tight :Word:
Some heat from a torch will loosen that wretched loctite :nice:
I hate that stuff :notnice:
Give me the Good Ole Days when all they used was a lock washer :D
Grady
You can't use a swivel with a torque wrench. If you absolutely have your heart set on a torque wrench, you can jack the car way up, and lower the axle all the way down. Then you can get in there with about a 12" extension. Not worth it in my opinion.
Kurt
Thanks for the ideas guys. So far a box wrench has been the only real champ on tightening these 4 bastards. I put on a multi point 12mm with a short extension to try to reach around the edge and its just not flush enough for my liking to give it a real go. Of course you gotta keep the wheels locked down during the whole operation so that means they need to be on the ground for me. Such a not fun way to finish a car.
You first might wanna jack the car up and turn the drive shaft so you car get the wrench on it flush. There's a certain spot that the socket will fit flush in but you gotta have it jacked up and in neutral so you can turn the drive shaft. A car lift with a dewalt cordless impact is ideal lol.
Yup, then after you turn it to that sweet spot put the e-brake on to help keep it from turning or put it in gear (forward or reverse depending on which way you are turning the bolts...loosening or tightening).
I just jamb my feet up against tires. Saves time, unless you have someone else to keep pull the e-brake for you.
Kurt
That works too if you're not laying on a creeper...lol
I always forget about the creeper rolling and half the time when laying under the car and I first go to remove a bolt I end up just pulling myself further under the car
I put the tires on a couple blocks, that was more than enough clearance for me to get under there and hit it with a box wrench and some locktite. I was damn near bending the wrench while tightening, so i hope it holds.
I gave up on creeper's years ago. About all they are good for is jambing your arm skin under the wheels.
Kurt
