- May 27, 2011
- 4
- 0
- 1
I have an '04 GT 5speed with stock gears but was thinkin about gettin some new gears but not sure what would be good for a daily driver?
FYI, when you post a thread, provide as much information as you can about your car. Fill out your profile and post a signature. That way, people can give you better advice about your setup.
With that being said and no other info. 3.73's. 4.10's do nothing except spin tires on the street unless you have the proper traction to handle it, and they do nothing at the track unless you have(again) the proper traction to handle it. Your car won't be any faster on the street with 4.10's over 3.73's unless you are dead hooking.
The benefit of 4.10's, and even more with 4.30's, is that the lower gears are ideal for the 1/4. They put you higher in the powerband and optimize your power between shifts. However, if you can't 60ft, gears are worthless.
I DD a 2001 GT With 4:10s and Average about 19-20 on 87 octane 21-23 on premium. The only downside is how loud it is on the highway, But imo that's a good thing
Your gears were installed incorrectly. They shouldn't make a sound.
Think he meant loud as rpm wise, i dd 4.30's, and i have no complaints at all, but 90 percent of my driving is in town at about 50-55 which is about 2k in 5th which isnt unbearable at all, even on the highway (40 minutes to the track) the car turns about 3-32k idr, but its not that loud because even at a high rpm in 5th it has no load on it so just makes a cruising noise, not like 3k in first with a load on the motor its loud, if that makes sense, id reccomend atleast 4.10's
That is what I meant, I also have longtubes and a full exhaust, just cruising at 2700-3000 rpm is freakin loud
Any thoughts gear heads?Not a thread hijack but what you guys make of this?
My FR 4.10s are run in. Nice dry day. Took the car out for a WOT run and hard launch. I`m not the hard launch kinda dude but I thought I`d try it anyway as I`d never tried it.
Car is a 2003 GT Auto. Diablo 93 tune, Accufab plenum TB, K&N, catback etc. You get the picture. BEFORE the 4.10s went , on stock 17s and 3.27s the car could spin a tyre, no problem and chirp 1st/2nd easily.
Now after the gears I`ve added 18s with Michelin Pilots 295/35/18s.
Whats the deal? Was I expecting too much from the gears? It either feels like I`m down on power or I have plenty traction. I mean the car certainly tramps to 3 figures in no time and it drives fine so it can`t be power thing surely. It just doesn`t feel as `frantic` as I thought. I watched a couple of 4.10 videos on youtube and they seemed more `fun`.
I`m actually thinking now I can go down the blower route even with the 4.10s.Any thoughts gear heads?
).... (and having more traction could nullify the added weight but lets not make it complex). The only way to compensate for added weight is to add more hp.
You can add gears and they keep you in a nice powerband perfect for a 1/4 mile type environment but gears don't add hp; they help a good driver stay in the right place in the powerband and with practice could potentially help the ET in the 1/4 mile.You did two things at the same time. Bigger/heavier wheels with I'm assuming stickier tires (don't know what you had before) and 4.10 gears.
