Anyone know where (besides ddmtuning) I can get LED turn signal bulbs? And if so, what is the bulb number that I will need?
Thanks!
Thanks!
Thanks!
3157 is the bulb size for the tail-lights but, the amperage is way to high from that part of the wiring harness and will give you electrical problems.
The 2 inside bulbs of the tail-lights tend to run off of a lower amperage so LED's would work.
You can buy kits off of ebay to trick your car into thinking there is no blown tail-light bulb.
If I buy resistors that keep the car from thinking that the bulbs are out, will it still cause problems? Or is the fact that the blinkers will appear to be out the problem you were referring to?
Recon 99-04 Mustang LED Brake Light Kit (Includes 6 LED Bulbs) [264207WHX6] : Lethal Performance, Performance parts for Ford Mustangs
They will not work with sequential kit however.
Well crap I've got the sequentials..
ddmtuning has different relays that you can buy to replace the stock one instead of having to use resistors. Anyone know anything about these?
What? Ipod.. no ipod.. take it back and get something for the mustang... Lol. So how do you like the sequential tails? Were they hard to install or was it mainly just a splice and plug thing?
I too was hoping to go LED with the sequential taillights. I bought these AutoTrix :: 96-04 Mustang and the flasher. The flasher slows the taillights down and I love it. Best taillight kit ever!! If you have a kit, you should be able to replace your flasher with this one and it should slow them.
