Where does the black ground wire go that hangs from the EFI Harness (S&P Shakers)?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
I am putting the engine back together and have a black ground wire hanging from the EFI harness (below the salt and pepper shakers) that I am not sure where it originally bolted up to?
1993 5.0.
Thanks in advance.
Check the wire color and stripe against the diagram. You may want to use some mineral spirits to clean the wire up so that you can clearly see the main color & stripe. If you don't find it on the diagram, check out the rest of the diagrams on Tmoss & Stang&2birds site.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring Mustang FAQ - Wiring & Engine Info Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
Found out, it bolts to the exact location where you bolt the "firewall to driver side head" ground. There will be two grounds at that location.
Thanks for the help fellas.
