Help removing
I am want to remove the ac unit from my car for two reason, one its is dead as a doornail and two to reduce weight.
I read the procedure to remove the condenser. and it states for me to remove the front grill. I can't beleive I would have to that. If I remove the radiator can I slip it out that way?
can you be a bit more specific:D
You asked a specific question and I answered it. How much more specific do you want? :D
After you remove the radiator, all you have to do is disconnect the lines to the condensor, remove the two retaining brackets at the top and the condensor will come right out.
Fix A/C and use it, unless you plan on going John Force fast. I regret deleting my A/C.
X2 too many times i see people remove their a/c and do things along those lines, then later they end up not liking the car and want luxury items such as a/c. one of the things people love the new 5.0 is because it has power,good brakes and tons of luxury. just fix it! its not worth the minimal weight savings. in the long run you will be happy you kept it. just my 2 cents though
Meanwhile you're telling him to remove the radiator. Shaolin, you're a cool guy and I respect your tell it like it is attitude. But, not everyone knows everything about everything. That's why we ask questions. To learn.
Wanna know why i said to remove the radiator? He's having obvious issues with the car, meaning if the a/c was never maintained then other thing most likely werent either, like the cooling system, meaning its probably a good idea to change the coolant and radiator hoses, so might as well pull it out. Dont forget how he worded his question.
Nobody is telling him to remove the radiator.
Note the original question:
The answer to that is "yes".
Personally, if I had just bought this car, I would be pulling the radiator and, at a minimum, blowing the crap out of the fins and checking it over closely for leaks, as well as changing the coolant. From there, removing the condensor is a two minute job.
The only think wrong with the car is the air conditioner nothing else. But I will go going through the complete car and rebuilding the front end making sure that the suspension will not bind as the front end rises.
I would be doing this even if this was a 2012 Mustang
