Catalytic Converters help :(
In the diagram the HAVAC and RESIVOIR don’t appear to be mounted to the firewall that’s why im confused…
The drawing is a schematic. It shows the relationship of each part to each other, but not exactly how they are mounted in the car.
Dude, I can't tell you exactly how to do it without being there. You want a vac source going thru the check valve, then to 4 places.
1. HVAC (firewall)
2. TAD solenoid
3. TAB solenoid
4. vac resevoir (fenderwell)
Before the check valve, a line of vac source should go to the EGR vac regulator.
1. HVAC (firewall)
2. TAD solenoid
3. TAB solenoid
alright, so everything "appears" to be hooked up the way it should be there is one last hiccup i checked the charcoal canister and my fuel evap is there is was unhooked but it is there and i fixed it. so the 3rd black broken line is still a mystery... or its actually the resservor line and the non broken line is a mystery... pic E btw thanks i really appreciate all the help
So there's 3 lines coming out of the fenderwell? Only thing I can say is to remove the plastic inner fender lining and see what you've got. On my 87, out of the inner fender, there was 1 fuel tank vent line going to the charcoal can, and a single vac line going to the vac resevoir.
Small update I haven't had a chance to open the fender well to see what that 3rd black line is but I will get to it eventually. Although I was checking my spark wires yesterday and i noticed under my air diverter the hose was cracked really bad and it wasn't heat wrapped and the damn thing is so old I tried to pull off the hose and broke off the bottom half of the diverter...
