Is there a particular reason you don't want to use coil overs, or is it just to save a few bucks? From what I've read, if you use the Moroso springs, it's a good idea to bag the right rear to keep down the body roll. 90/10 struts, and 50/50 shocks would be a good start, but keep in mind the struts will alter the way the car handles on the street. When you set a car up for 1/4 mile, your street driving gets a little "loose", so don't expect to cut corners as fast as you used to. Another quick way to get weight transfer is to remove your front sway bar...drops a little weight too.
Don't neglect your chassis though when you're setting up for drag. I'm sure you already know what's happening to the car when you launch-everything is shock loaded, and fox bodies aren't known for being robustly built. So, if you haven't put in some subframes, and reinforced your torque boxes-or at least welded them-you're looking at creating some damage. Depending on how far/fast you wanna go, you might wanna look into buying a cage of some kind. There's nothing really wrong with your setup, but there are a few other little details that will help you hook better on the track. If you can swing it a good set of adjustable uppers would allow you to adjust your pinion angle. Better lowers would be a good investment too...the factory bushings leave much to be desired.
