I have a bad drain which based on a TON of searching tells me it is a bad amplifier. Can someone tell me where the factory amps are located in a convertible? If you have a pic, then you are simply awesome!!!
Thanks, Josh is correct. All are removed. Let's see if this fixes my battery drain issue. When I bought the car I noticed there was no bass from the audio system. While reading about batery drain issues, I came across a thread about a guy who lost all bass and was having a battery drain issue, turns out his right rear amp was dead short and draining battery. I plan to add an aftermarket system, so I removed everything. Fingers crossed
Do some research before you add aftermarket, its tricky to get all the Mach speakers and aftermarket add-ons working at the same time, but it can be done and sounds fantastic.
