Sparkplug issues
So the thread in my sparkplug is wacked Out. It keeps on spinning not actually loosening so what can I do to remove it. I already purchased a helocoil just need to get the old plug out but don't know how to. If you have any feedback please let me know ASAP. I think I'm running on 7 cylinders right now
I would not Recomend a helicoil once
you get it out , read the horror stories on them... go look for a time sert kit you'll thank me later .
As far as getting it out are you sure the plug isn't stripped where the socket goes ?
just to do a check try a reg 5/16 deep socket and see if that bites I just can't see the plug turning and. not coming out .... if it was cross threaded you would no but no matter what it would come out
Check to make sure there isnt any debris in the cylinder that is down by the head of the sparkplug. I had a similar issue once and a little stone had fallen down in there keeping the socket from fully seating on the plug. If there is something in there you can blow it off with a little compressed air.
Thanks bro I got It off there was a plastic peice in the way but I have another problem the new coil that I got caught on fire and I don't know why. It was a accell coil and it has happened to two of those coils. Idk what is going on any idea.
Accell=Crap. Get your money back...............that being said, you can fry a coil by leaving the ignition switch on for a long period of time, coil has power to it and it just sits there and cooks.
You have to verify that the ignition coil does not have power to it when the key is off first. The only way for a coil to cook is if there is power to the coil and the engine is not running.
I switched it out with diff plug n it still blew up. I'm lost bro
hat's because the spark plug is NOT the problem. It's either the coil or a wiring short that is burning the coil out.
And get rid of the Accel coil. Nobody makes an aftermarket coil better than the factory part so don't waste your money. Get your money back from whoever you bought the two Accel coils from and get the electrics tested and fixed before buying a new coil.
