An earlier post I asked what water pump was best for cooling. Now I would like some opinions on if a Taurus or Contour duel E Fans would outcool a Flex-A-Lite Extreme cooler fan?
That is what I read also for the Flex-a-Lite. I am currently using the Extreme Puller but am entertaining the thought of using the Taurus/Contour fan. You can even get one of those from Rock Auto new for less than $100The flex-a-lite pulls 3300cfm if I remember correctly. I'm also relatively sure that the Contour, 3.8 Taurus, and Mark VIII pull 3600, 4000, and 4500 respectively. All of which will cost a fraction of the Flex-a-lite. Those 3 fans are used by people everywhere from Mustangs to even Jeeps and Corvettes.
What scott said
I have a Mark 8 fan and it works very well
What year Mark VIII fits an 87GT???
If a Mark III fan is not available from a salvage yard, RockAuto has the fan and motor sold seperately. $218.58 for the both. Yes that is fairly pricy but if you price a Flex-A-Lite Extreme Puller fan like the one I have those are well over $300. Not bad for the Mark III considering it pulls 4000 CFMs compared to the Extereme Pullers 3300 CFMs.
As for a controller for mine, I am using a Flex-A-Lite Veriable Controller.
Get a Mark viii fan on ebay even...Trim the tabs and stuff. I cant remember off hand but i believe there is a 40-45 amp draw when it kicks on. So if your alternator is under 100 amps it is strongly recommended that you upgrade.
It's actually about 70 amps. Most people that don't have controllers use a 75 or 80 amp relay and a switch to turn them on and off manually. A PWM controller would definitely be the best option though.
