gearing is everything
Just think , if you had a car weighing 2600 pounds and rear wheel torque of just 400 ft/lbs How fast do you think that car would be off the line? Gearing is everthing. The best bang for the buck when building a street car is the gears. When I bought my car the first thing I did was get rid of the dead rear. 2.73 to 3.55 what a difference that made alone
I don't dispute that.................but torque measured at the rear wheels does not change.
There is a difference between torque and torque multiplication. Engine torque does not change with a ring and pinion swap (as Bullitt mentioned). The torque multiplication is where the difference is. Apples to oranges here.
Reactions: 88LX5.Oh
You are absolutlely right, but it is gearing that makes that engine torque usable.
l torque goes down as you shift gears. The gear reduction through the tranny is deepest in 1st gear. You want torque just keep your car in 1st. In 5th the torque is the lowest.
The only way engine torque goes down is if you change something on the engine. For the sake of oversimplification...........if the engine makes 200 lb/ft of torque at the tires from idle to redline, it does not matter what gear you have, engine torque is always 200 ft/lbs. What gear you are in will effect tire acceleration to a given rpm, but you still only have 200 lb/ft of torque used. Because a 4.56:1 gear makes use of that torque easier, the acceleration is greater, but only to a limited mph. A 1:1 gear makes the 200 lb/ft act sluggish, but it is still 200 lb/ft, with the end result being a slower initial acceleration but with a much higher theoretical mph. Either way, there is still 200 lb/ft of torque to the tires.
This whole thread was started by some guy that got drunk and logged in to post some babble about some babble he read somewhere else and your arguing only gives validity drunk babbling. Or maybe we're all drunk on here babbling about babble. Like a bunch of drunk guys with a laser pin playing with a dog. It's all pointless. My babble right now is just useless babble about other peoples babble and now i'm going to get back to work since i'm on the clock and shouldn't be babbling.
to the OP, my screw gun puts out more torque than your screw gun. I'm cooler than you so :zipit:
Is everybody in Spokane as vicious as you.? Remind me never to go there.
You are right. But rear tire force is what accelerates the car not engine torque. Rear tire force is engine torque times all the gear ratios and rear tire diameter.
And what is "rear tire force? Where does it come from? Oh that's right.............it comes from the torque that the engine makes..........hmmmmmm.......maybe that is why on a chassis dyno you get 2 power numbers.....rwtrq and rwhp. Yup rear wheel torque is what is measured on a chassis dyno, the same torque that came from the engine. Calling a horse by a different name does not change the facts, and that is torque at the tire does not change.........period. It does not matter what gear you are in. If your argument was only about gear reduction...........well, then we would not have any disagreements. Gear reduction and torque are two different animals completely.
I'm timid in comparison to others. With threads like this it gets hard to use the search feature in tech sites for people with genuine problems that need help. The search feature gets cluttered with junk results when discussions get watered down with social media type conversations instead of tech related problem solving issues.
My $.02 is that the moderator should move this thread under the FOX TALK section, not tech, so people can chit chat about how much bigger there thingy is over someone elses (IQ numbers is what i'm talking about).
I kinda get what dude is saying, and dispute everybody stating that torque is torque
Even using a Dewalt 24v drill as an example, the high setting offers speed in exchange to trading off the ability to turn a Gi-honkin 2" auger bit at that speed.
Put that sucker on low speed by effectively reducing the gear ratio, and God help your broke ass arm if you hit a nail with that same Gi-honkin auger bit chucked up.
The lesson that your shattered forearm is testifying to is that torque just got multiplied exponentially by a simple gear change.
Nothing got changed electrically in the drill motor to increase it's output, so how the hell did the same drill that I could drill a hole on "3" while holding it w/ one hand, just frag my forearm after I changed the speed setting to 1?.
I'd be curious to see what a chassis dyno pull would be on any engine given the rear gear ratio could be reduced to a 1:1, and then compare the same combo w/ whatever "normal" rear gear ratio typically ran against it.
Gearing is equivalent to leverage. That is all. Saying your underpowered harley puts down 1085 ft/lbs to the pavement makes you sound like a moron.
Leverage is equivalent to torque.
A longer breaker bar increases your "leverage" and allows for greater "torque" when breaking loose 460 head bolts, torqued to 140 ft lbs..
Can I just share a true but embarrassing story of my travel from 16yr old school boy to mechanic.. Long story but short and easy to visualize. Picture a pair of dually tow truck wheels removed without unbolting the lug nuts. Pulled the center axle and loosened the bearing retaining nuts. Hub, drum, wheels, etc laying on the ground. Stripped axle bolt hole in the hub. 60+ year old mechanic hands me a drill to drill the hole out for a helicoil. 3/4" chuck T-handle electric drill with a recently replaced switch...TOGGLE SWITCH! I weighing 125lbs back then stood on top of the wheels turned on the toggle switch drill and proceeded to drill. Then the bit grabbed and I experienced TORQUE. Torque = two hands on a drill with a toggle switch you can't let go of while you wrap the cord around your feet and damn near break your arms.
