The only way engine torque goes down is if you change something on the engine. For the sake of oversimplification...........if the engine makes 200 lb/ft of torque at the tires from idle to redline, it does not matter what gear you have, engine torque is always 200 ft/lbs. What gear you are in will effect tire acceleration to a given rpm, but you still only have 200 lb/ft of torque used. Because a 4.56:1 gear makes use of that torque easier, the acceleration is greater, but only to a limited mph. A 1:1 gear makes the 200 lb/ft act sluggish, but it is still 200 lb/ft, with the end result being a slower initial acceleration but with a much higher theoretical mph. Either way, there is still 200 lb/ft of torque to the tires.
