I had a company that does suspension do all the work that's why I changed all the bushings. I thought the same thing about lubing the bushings and everyone said that the bushings shouldn't be lubed because the bushings would slide out.
So basically, you took your car to a shop to fix a squeak, paid them a bunch of money to put on new bushings, struts, and shocks, and still have a noise?
Did you ASK them to put the bushing kit in, or did they RECOMMEND it as a repair? Basically, if this was their recommendation to fix the squeak and it didn't fix it, then you need to be talking to that shop. If they are unwilling to do anything for you, please don't give them any more of your money.
Other information we need...
What kind of bushings (Rubber, Delrin, Urethane, etc.)?
What bushings does the "bushing kit" consist of?
What other modifications have been done to the car?
Are the springs stock or aftermarket? If aftermarket, who installed them?
Do you have spring isolators? Are they stock rubber, or a different material?
When do you notice the squeak?
It does exist and I will post some soon.And pictures, or the car doesn't exist..
I have stock springs. I had them install the total bushing kit, struts, and caster cambers thinking that would take care of the problem. There's not any mustang shops besides the Ford dealership around here.So basically, you took your car to a shop to fix a squeak, paid them a bunch of money to put on new bushings, struts, and shocks, and still have a noise?
