- Jul 12, 2011
- 739
- 35
- 39
Ok, first off i know about the checklist and all that but i cant follow diagrams and lists if my life depended on it. so i bought a notch that has a 306, holley heads, cam, trick flow intake, intake spacer, egr spacer, CAI, 30# injectors, smog delete and its an 87 with mass air conversion. the problem is that is has a hard time starting and while its starting it backfires threw the intake alot. and when it starts it won't idle until its warmed up. then whens its warmed up the idle surges. ive cleaned mass air and checked voltage on tps for now. my next step was vac lines but there's hardly any lol. everything looks capped off..the egr spacer has caps on both sides, egr itself has no line on it, lines on the intake haves bolts shoved in them and im more or less overwhelmed and don't know where to start.
