New Heads
Sep 8, 2013
94
11
I got the new heads for my car yesterday. Can't wait to start the build up.
It has not been corrected. I also ordered the spring kit from Ed at flowtech induction to replace them. I'm running the comp cams stage 3 cam XE270HR, that was delivered about an hour ago, so I knew I was going to need to replace them. I just could not beat the price even with the spring upgrade.
I got a deal on a typhoon intake ( edlebrock nock off ) but i ported it matched the gaskets and polished up the runners in it really good. Spent half a week working on the inside of it, after work. I probably will get the car on a dyno when I'm done just so I know what I built. I am really hoping for 300+rwhp. It should be plenty for the wife.
I should add I'm also running a bbk 70mm throttle body and bbk headers, 24 pound injectors and mass air sensor or at least that's what I bought to run. I'm sure some things will change along the way. Any recommendations on a stall speed? I think 2200-2500 would be good. How about a good balancer? I need to get one still.
It's good to see someone do some research before they purchase. My understanding is that those heads work great with the spring upgrade. Let us know how they work out in the end, and how much the heads ended up costing you assembled if you could.
Kurt
Now you're making me wish I had upgraded my springs when I got those heads. Oh well I just have a B cam lol.
As for stall speed, I'd go with what you came up with. And also that cam is designed to go with 1.7 rockers. So if you end up using 1.6's you're gonna lose a little lift. Just letting ya know because most people don't think of this or even see it in the products description
BTW are these the 2.02/1.60 heads or the 1.90/1.60 heads?
They are the 1.90/1.60 heads just got them back from the shop today and they look great all ported and polished up inside. I do have a set of 1.7 roller rockers for it as well. My buddy came over and installed the cam in the block today, he knows how more about degreeing a cam than I care to learn and he has the tools to do it. I managed to miss place the dang cam gear bolt so we quit for the day. I still have to put the heads back together then I can bolt them on.
Can't believe the E brock heads still haven't address the springs... I bought a set of performer heads way back when and the damn springs ate through the pads, plus the guides were absolute crap. Glad you had yours checked out before install.
Well checked PTV Clearance and failed with stock pistons. It tore thru the clay guess trying to use a stock bottom end was a bad idea. Anyone have a recommendation on a set of pistons with better valve reliefs. Thanks
