Suspension Do I Need Castor Camber Plates
Yes and no... They are the easiest/best way to get correct caster/camber. However you can slot the strut bolt holes to achieve the same result but that method has it's own likes/dislikes....
Just buy the cc plates and be done with it.
I simply prefer the more positive adjustment with the aftermarket plates. The factory rubber bushings in the top of the plates you currently have are most definitely worn and I would recommend replacing them if your budget so allows.
