Low Rpm Lean Pop Trouble
See the section below on testing the O2 sensors before you swap or replace them...
Code 41 or 91 Three digit code 172 or 176 - O2 sensor indicates system lean. Look for a vacuum leak or failing O2 sensor.
Revised 29-Sep-2013 to add back in a clogged crossover tube as cause for code 41
Code 41 is a RH side sensor, as viewed from the driver's seat.
Code 91 is the LH side sensor, as viewed from the driver's seat.
Code 172 is the RH side sensor, as viewed from the driver's seat.
Code 176 is the LH side sensor, as viewed from the driver's seat.
The computer sees a lean mixture signal coming from the O2 sensors and tries to compensate by adding more fuel. Many times the end result is an engine that runs pig rich and stinks of unburned fuel.
The following is a Quote from Charles O. Probst, Ford fuel Injection & Electronic Engine control:
"When the mixture is lean, the exhaust gas has oxygen, about the same amount as the ambient air. So the sensor will generate less than 400 Millivolts. Remember lean = less voltage.
When the mixture is rich, there's less oxygen in the exhaust than in the ambient air , so voltage is generated between the two sides of the tip. The voltage is greater than 600 millivolts. Remember rich = more voltage.
Here's a tip: the newer the sensor, the more the voltage changes, swinging from as low as 0.1 volt to as much as 0.9 volt. As an oxygen sensor ages, the voltage changes get smaller and slower - the voltage change lags behind the change in exhaust gas oxygen.
Because the oxygen sensor generates its own voltage, never apply voltage and never measure resistance of the sensor circuit. To measure voltage signals, use an analog voltmeter with a high input impedance, at least 10 megohms. Remember, a digital voltmeter will average a changing voltage." End Quote
Testing the O2 sensors 87-93 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear.
Disconnect the O2 sensor from the harness and use the body side O2 sensor harness as the starting point for testing. Do not measure the resistance of the O2 sensor , you may damage it. Resistance measurements for the O2 sensor harness are made with one meter lead on the O2 sensor harness and the other meter lead on the computer wire or pin for the O2 sensor.
Backside view of the computer wiring connector:
a9x-series-computer-connector-wire-side-view-gif.71316
87-90 5.0 Mustangs:
Computer pin 43 Dark blue/Lt green – LH O2 sensor
Computer pin 29 Dark Green/Pink – RH O2 sensor
The computer pins are 29 (LH O2 with a dark green/pink wire) and 43 (RH O2 with a dark blue/pink wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
91-93 5.0 Mustangs:
Computer pin 43 Red/Black – LH O2 sensor
Computer pin 29 Gray/Lt blue – RH O2 sensor
The computer pins are 29 (LH O2 with a Gray/Lt blue wire) and 43 (RH O2 with a Red/Black wire). Use the ground next to the computer to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Testing the O2 sensors 94-95 5.0 Mustangs
Measuring the O2 sensor voltage at the computer will give you a good idea of how well they are working. You'll have to pull the passenger side kick panel off to gain access to the computer connector. Remove the plastic wiring cover to get to the back side of the wiring. Use a safety pin or paper clip to probe the connections from the rear. The computer pins are 29 (LH O2 with a red/black wire) and 27 (RH O2 with a gray/lt blue wire). Use pin 32 (gray/red wire) to ground the voltmeter. The O2 sensor voltage should switch between .2-.9 volt at idle.
Note that all resistance tests must be done with power off. Measuring resistance with a circuit powered on will give false readings and possibly damage the meter. Do not attempt to measure the resistance of the O2 sensors, it may damage them.
Testing the O2 sensor wiring harness
Most of the common multimeters have a resistance scale. Be sure the O2 sensors are disconnected and measure the resistance from the O2 sensor body harness to the pins on the computer. Using the Low Ohms range (usually 200 Ohms) you should see less than 1.5 Ohms.
87-90 5.0 Mustangs:
Disconnect the connector from the O2 sensor and measure the resistance:
From the Dark blue/Lt green wire in the LH O2 sensor harness and the Dark blue/Lt green wire on the computer pin 43
From the Dark Green/Pink wire on the RH Os sensor harness and the Dark Green/Pink wire on the computer pin 43
91-93 5.0 Mustangs:
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 43
From the Dark Green/Pink Gray/Lt blue wire on the RH Os sensor harness and the Gray/Lt blue wire on the computer pin 29
94-95 5.0 Mustangs:
Computer pin 29 Red/Black – LH O2 sensor
Computer pin 27 Gray/Lt blue – RH O2 sensor
From the Red/Black wire in the LH O2 sensor harness and the Red/Black wire on the computer pin 29
From the Dark Green/Pink Gray/Lt blue wire on the RH Os sensor harness and the Gray/Lt blue wire on the computer pin 27
There is a connector between the body harness and the O2 sensor harness. Make sure the connectors are mated together, the contacts and wiring are not damaged and the contacts are clean and not coated with oil.
The O2 sensor ground (orange wire with a ring terminal on it) is in the wiring harness for the fuel injection wiring. I grounded mine to one of the intake manifold bolts
Make sure you have the proper 3 wire O2 sensors. Only the 4 cylinder cars used a 4 wire sensor, which is not compatible with the V8 wiring harness.
Replace the O2 sensors in pairs if replacement is indicated. If one is weak or bad, the other one probably isn't far behind.
Code 41 can also be due to carbon plugging the driver’s side Thermactor air crossover tube on the back of the engine. The tube fills up with carbon and does not pass air to the driver’s side head ports, Remove the tube and clean it out so that both sides get good airflow: this may be more difficult than it sounds. You need something like a mini rotor-rooter to do the job because of the curves in the tube. Something like the outer spiral jacket of a flexible push-pull cable may be the thing that does the trick.
If you get only code 41 and have changed the sensor, look for vacuum leaks. This is especially true if you are having idle problems. The small plastic tubing is very brittle after many years of the heating it receives. Replace the tubing and check the PVC and the hoses connected to it.
jrichker: Thanks for posting the o2 sensor testing procedures. I've those bookmarked for awhile now, but it was a good reminder.
On that note, I decided to break out my analog meter and retest the o2 sensors... They are both now only switching between 0.01 V min, and 0.03 V max at idle. Last time I checked them (last month) they were switching between 0.2 and 0.6 at idle. Looks like I'm in the market for some new o2's.
edit: My question is, why wouldn't it be throwing lean codes 41 and 91 anymore if the o2's are actually that far out of spec?!
Are you sure the batteries (if any) in your meter are good?
Maybe the O2 sensors are dancing on the edge of the cliff, just about to fall off...
Definitely a good battery. I never store my testing equipment with batteries in it, so I had to put a new one in just for this test. Sounds like you're right about them about to fall off. I performed the Ohms test on the harness and it's right around 0.5. The engine grounds are all good, and I've actually added extra grounds strategically to avoid voltage loss with my battery being in the trunk. I'll see if I can pick up some Bosch direct fit replacements tomorrow, and report back. If I can't find direct fits, I'll just order some Motorcrafts on Monday. I'm not a fan of those universal Bosch o2's. Splicing a harness that relies on incremental voltage fluctuations to operate properly doesn't sit right with me.
So I spent last night troubleshooting the MAF, and contacted a rep at Pro-M Racing this morning to see what their thoughts were. Turns out it's not the MAF. According to even the Pro-M rep, it's an ignition problem. I ran diagnostics with them on the phone, and they confirmed the readings I was getting were accurate (acceptable anyway). I even ran the engine with the MAF unplugged, and the popping was still there with the same frequency. Their guess was that it may be attributed to spark scatter in the distributor. They advised me not to purchase one of their MAF units until I rectified the ignition issue. I've got nothing but good things to say about those guys, and I'm glad they're back in business.
I have a known working TFI module that I will start with, and then throw in my spare dizzy if that doesn't work. I have an old MSD 6a box and coil waiting to go on, but I don't want to add that into the mix until I've nailed down this issue. I'll start testing the ignition system one component at a time to see what's going on. One thing that comes to mind is the Ford Racing plug wires that I have on there. They were new when I installed them, but I've had issues with their wires in the past. Seems like the quality control with those wires sucks for some reason (outsourced?).
Is it a stock or MSD ignition system now? If MSD, take all that crap off and I bet the issue goes away. For the wires, bring the car into a garage or somewhere dark and with the engine running take a spray bottle and light;y mist the wire- if you see arcing then the wires are shot.
The TFI normally shows up as a warm no start or dying out, not a popping. If you have a spare stock distribtuor, TFI, and coil, I would put that on and see what happens.
Stock ignition system, except for a Crane Fireball coil. Like I said, I'm not putting the MSD ignition box or coil on until these issues are sorted.
I'm certain the wires aren't arcing. I have done the spray mist test just to be sure though. The issue that Ford Racing wires are known for is having too much or too little resistance, or having varying resistance amongst wires within the same set. That could possibly be happening here. I'm going to check the resistance of each of these wires tonight. My headers are also wrapped like mummies, so I'm not concerned about the boots being melted either. The wraps are ugly as hell, but I can grab a primary with my bare hand after sitting in rush hour traffic without getting scorched haha. My under hood temps are nice and cool.
I agree that most of the time a faulty TFI module will cause issues only when it gets hot, and create a no start until it cools down. It is possible to have an intermittent issue with the TFI though. I'll swap it with my OEM spare and see what happens
Thanks
The more i read this the more it sounds like the bad msd distributor i had. It only surfaced when i installed a 3g alternator and it went berzerk. If you're in the atlanta area, i got a spare refurb FoMo one you can slap in to check.
coil isnt going to cause your issues. Coil either works or it dont. Yours does, its fine Now you van ohm it out to see if its still within the manufacturers advertised specs, but unless you've got a high dollar racer where every millisecond counts, you'll never notice any difference even if its out of spec
liljoe07: The timing is pretty steady at 20 degrees while it's popping under 2,000 rpm. It clears up dramatically over 2,000 rpm, which is where you can see the timing comes in more aggressively.
Can you take a picture of the distributor from the front of the engine and post it?
I'm not going to take what you said personally about where to check the timing, because this is the internet and you don't know me personally, and have every right to assume I'm an idiot... That being said, I did get a kick out of your question haha. Yes I'm sure I checked the timing properly.
LoL! I hate to ask questions like those. But Id rather ask and know, than to assume. Youd be surprised at how many have done that!
Thank you for reminding me about the vacuum, I forgot to mention that earlier. There are no known vacuum leaks on the engine. I've smoke tested, and sprayed ether on just about everything to double check it. For a cammed motor, I have noticed that this thing pulls an insanely high amount of vacuum... about 25 in/Hg at idle. It's so much vacuum, that even though my fuel pressure is set at 42 psi with the vacuum off, it drops to 29 psi with the vacuum applied to the regulator. I've never seen so much vacuum on a cammed 5.0. I've always seen more like 15 in/Hg at the most. I did try running the car without the vacuum hooked up at the FPR (plugged the vacuum line), but it made no difference either way. Thoughts?
That is interesting! The more vacuum the engine makes, the more the fuel pressure will drop when the vacuum line is connected. So the numbers are believable. But it seems vacuum is kinda excessive in your case. Almost make me want to question the cam timing. :chin
Woah I didn't realize I had so many responses since last week. I stopped getting email notifications.
Here's the update: I replaced the TFI module, and as suspected nothing changed. I finally got around to taking the Crane Cams Fireball coil off tonight, and temporarily replaced it with an MSD Blaster 2 coil that I had laying around... I think it may have worked! I won't be able to start it up again until tomorrow (don't wanna wake the kid), but I'm pretty sure the issue was either with the connection to the coil, or the coil itself. Not sure if anyone here has seen the connector on the Fireball coil, but it's pretty goofy. It splices into the factory wiring, and the connector itself is a rubber block with two female bullet connectors inside of it. The coil has two male bullet connectors. Well my negative connection inside the rubber block was pretty loose. There would be no way to tell that without taking it off, and looking really closely inside the rubber block.
I installed the MSD coil because the connections were easy to temporarily join with the existing Crane connections (after fixing the defective negative cable). Fingers crossed that this was the issue.
madspeed: That's what I've seen too, but this may be an exception. Of course, it could have just been the loose wire. I'll know more after I drive it tomorrow.
liljoe07: I'll take a photo of the dizzy tomorrow for you, but until then I can tell you that the plug end of the TFI module is clocked at about 4:00. I think I know what you're getting at, and it's definitely not off a tooth. Based on experience, it looks pretty close to 10 degrees initial. I stabbed this distributor while it was on the stand, before I even rotated the motor, so I'm pretty sure I got it right.
LOL. I've seen people do some pretty dumb things when running diagnostics, but that one cracked me up.
I installed the cam straight up (no advance) according to the specs on the cam card. I also checked it with a degree wheel and everything lined up perfectly. I'm positive on this one, because when I first installed the cam I installed it 180 degrees off (I was in a rush and lined the dots up backwards DOH). I didn't get even get the timing chain back on before my brother pointed at my mistake and laughed his ass off. It was a late night, but we decided we had better take our time and degree the cam properly after that. It's definitely in straight up with no advance.
5.yellow: I'm in Miami.
Thanks again guys. I'll update again tomorrow afternoon.
Distributor didnt do it either... Guess it's time to focus on the fuel system. I have an A9P computer that I'm going to try as well just in case. I replaced my original A9L when it fried with an 8LD, and i just want to be sure its not hiccupping.
What sucks is that this may boil down to a simple wiring issue. I've been out of the foxbody realm for awhile now (been driving an SN95), and I'm now remembering all the wiring gremlins these cars can have.
