Cruzin'
Mine does, barely. After I hit accelerate one time it will increase speed by nearly 5 mph.
Funny, mine does nearly the same thing.
Tap it once and it actually drops a couple of MPH before recovering....usually about 2mph slower than it was previous.
If I want to increase the speed, I actually have to hold my finger on the button and let off a couple of MPH past my desired setting....then it drops those same 2mph and holds.
Wasn't sure if it was an issue with vacuum, or I'm just not remembering how crappy a 25-year-old cruise control set up can be?
Well... Mine used to work.. :confused: Was out and about today, but when I tried to cruise I got nothing...
This was working not long ago, and I don't see how it would be related to my recent little fender bender last week? Don't know much about the cruise control but hopefully I can find some trouble shooting details on the interweb.. So it looks like I've now got a project this weekend.
Woohoo.. I'm back and cruisin' again :nice:
I really hate electrical problems, and this one was particularly annoying since it was actually two things that went wrong at the same time. Turned out to be fairly easy stuff to fix, but it took a while to track down the cause(s).
In the event that this is of any help to the next guy who has a problem, between some helpful past postings on here from @jrichker (just use search for horn and fuse) and the following site:
http://www.thorssell.net/hbook/ccmain.html
I was able to track down the problem.
It was just a blown fuse that stopped the cruise from working, but unfortunately just replacing the fuse didn't work since every time I put in a new fuse it would just blow immediately. Turned out that one of my horns has a short in it and ALSO I have some shorting going on in my power window switch when it's on the passenger door mode. Disconnecting the bad horn (now I just have a wimpy horn since only the one good one is connected), and having the PW switch over on connecting to the driver door seems to have solved the problem. I'll prolly take a trip to a junk yard and find replacements sometime soon.
Mine did until i put the wheel in . it was worth it. one day ill hide the buttons in my ash tray door as that was always my plan.
Reactions: smkshw and Dan93fox
My '88 actually does NOT have cruise control. It's the only option it doesn't have which is funny because it's AOD, sunroof and even had the dealer-installed block heater put in. But no cruise.
So it's the one system on a Fox Mustang I have ZERO clue about.
Since my '88 was my first car that i drove for a while..i never used cruise control. So to this day, in my newer DD's, i still don't use it.
