Explorer Intake With Tall Valve Covers Question
BKM48198
377
27
49
Ypsilanti, Michigan
Without adding in a spacer is there a way to fit tall valve covers under an Explorer intake? I know I can take out one fitting and put a pipe plug in it but on the back of the intake there is a vac tube that sticks down, can it be removed and plugged and will the tall valve covers clear then? I don't want to remove it and find out it still won't fit, I'm hoping someone else has already tried and can give me some advice, Thanks.
Even if you relocate the vacuum fittings I don't think you will have enough room. The plenum dips real close to the factory covers. I don't see taller ones making the cut.
I know a 3/8" spacer works with a Cobra intake under the stock hood.
Not sure about the exploder intake though
Thanks, I'll cut a piece of wood that is 3/8in. and see if that gives enough room for the valve covers, I would really like to use the polished valve covers if possible. I might try a 1/2 in wood spacer too. I have the motor just about ready to go, should be able to get it all together tomorrow if the weather cooperates. I wanted to work on it today but had to pull the bed off my Ranger to install a new fuel pump, not the vehicle I want to be spending money on now.
