Ilike this guy talking junk about buying my cobra . C chevy guy get mad . Not me . Thanks ur the best . This is the only site for ford or car guy . Thank you all . I
Huh?sir your posts are very hard to read/understand. Please try to post a semi-intelligible sentence. Really not trying to bash you but man it's hard to follow your responses. You need to post the codes. Pics/video would help also.
The car will not run . It will not start at all . No codes at all and only 10 psi at the fuel rail . And I just change the intake gaskets from felpro cobra gaskets . And replace all the vacuum lines . The car was siting so it's likely a bad fuel pump . I hear it going on . So I just bought a new auto meter fuel psi gauge to be sure . And both gauges read 10 psi . . I been trid to up load pix . I can't get them on hear . After I install the new pump I will see what's up from there .Huh?sir your posts are very hard to read/understand. Please try to post a semi-intelligible sentence. Really not trying to bash you but man it's hard to follow your responses. You need to post the codes. Pics/video would help also. My bet is a vacuum leak from the intake gasket. But at this point it's just a guess.
well the pump could've died but the pressure rising as it reaches 0 in vac that's normal im sure you know , that' pressure is high i believe it should be 38 or so on an NA. car vac hose off . blower car I know is 42 psi but that doesn't apply hereI had a another market one on it . But bought a new BBK about two weeks ago no codes . Before the problem with the car started my gauge read 45 psi and would jump up to 50 when I would hit the gas
Oem 89 I'm in Fayetteville
