I pulled my motor out this last weekend. Tore it down. This is a 1980 302 block out of a Full Sized Ford. It has cross hatching that looks good! I was glad, but to my surprise the pistons have two valve reliefs. What's up with that? Not sure if it matters but the reason I pulled the motor was due to low compression in one cylinder. Squirt a little oil in the cylinder and the compression jumped back up. Bad Rings. Anything look different on this motor than what would come standard?
2015-2-14 Front Accessories Water Pump Removed (Rebuild).webp87.8 KB · Views: 291 -
