I'm trying to figure t393.6
Thanks I'm running a 373 gearPossibly 500-525 flywheel. Enough to run mid 10's with the right combo
Thanks it's also 40 over I'm running a 373 gear I'm hoping for at least low 10sPossibly 500-525 flywheel. Enough to run mid 10's with the right combo
And the rear end has a373 srange spool with 38 spline axlesYeah i know but i would like to at least run lower 11s high tens I'm running drag radial for now with adjustable lake wood lowers 3500 tci stall with a built c4 with a reverse valve body
Do you mean 33 spline? You should reach your goals. There are a few things I'm wondering about. #1- if your converter and rear gear is matched to your cam/power band? #2-what about your entire suspension combo? What's the cam specs duration wise?With a good combo you should reach mid 10's if it's not matched you still should be able to hit low 11's.And the rear end has a373 srange spool with 38 spline axles
Yeah my bad i ment 33 im not sure on the duration i know it's a 600 solid lift from bullet cam its being custom groun for my heads yeah everything is matched upDo you mean 33 spline? You should reach your goals. There are a few things I'm wondering about. #1- if your converter and rear gear is matched to your cam/power band? #2-what about your entire suspension combo? What's the cam specs duration wise?With a good combo you should reach mid 10's if it's not matched you still should be able to hit low 11's.
Thanks and I willI'm biased towards those cams lol. You should have plenty of power. You need to spec the torque converter to the cam for maximum efficiency. Good luck and post some pics if you get a chance of your project.![]()
Coors light, crayfish, and shrimp. The wife's catholicI had 3 soft tacos for dinner
Oh yeahif it has more around 280 advertised duration, you will need at least 10:1 static compression.
I would expect at least 230's [email protected] and more likely over 240 with at least 10.5:1cr. Op might see 550 flywheel hp and close to 500 ft lbs torque.
