A very long time ago.
Dislike!
As soon as he writes me into the will I'm having him killed.
Uncharacteristically on topic for me...
What are the primary differences between that clutch and something like the McCleod RST Twin?
First is cost. This clutch is lover $200 cheaper than a Mcleod setup. The second is hopefully performance. Dan over at Clutch Dynamics is a clutch guru to say the least. He studied the Ram and Mcleod clutches and made improvements on them. I don't know enough about the details of clutch design to intelligently talk about them, but Dan basically tweaked how the clutches engage. He simulates the engagement of every clutch he builds to make sure everything is spot on the way he wants it. The third is supporting small American businesses. I'm all for that.
I really like the new "blingless black" engine compartment.
It's ironic looking at it, it looks small in the engine compartment, and mine looks huge. Yours makes twice the power at probably half the boost, compared to me, and your engine will probably live for years, whereas I'll be constantly worried about breaking something, and will probably dial the engine back while you're turning it up.
Guess that's why there are 50 bazillion 5.0 builds, and one TTB six banger going on here.
It really is amazing how small the pushrod V8 is compared to other engines. Makes sense that it's the engine of choice for the Miata crowd.
. Once the motor cools and you re torque the heads, loosen the head studs one at a time 1/4 turn and pull them right up to 110 ft/lbs and you should be fine. No body I know like re torquing heads, me included... It is a necessity though.
