Smog Pump Exhaust Line
splogan
127
I have just about had it fighting with the steel pipe going to the h pipe. What effect will not hooking it up have if i plug the hole in the actual h pipe ?
Is that just a flexible rubber tube to take the place of the rigid steel one
Correct, you will cut the rubber tube in half, and put the steel tube (with clamps) in between the two halves of rubber allowing you to bridge the gap between the new H-pipe and the pipe coming from the air pump.
I assume that's what your problem is, correct? The new H-pipe changed the orientation of your smog equipment?
It reaches but somehow it came misaligned while installing the transmission and H pipe and it will be a cold day in hell before all that comes out again to align that thing
I would order that part, and use it.
Or you can cap it off, but like I said, I am unsure of how it will work with the thermactor air function still active in your EEC. I'd question where the air goes when the computer is telling the diverter valve to pump air into your cats.
If you decide to use the Walker part, I'd cut some off of the original tubing, allowing you to route it how you want.
