ok, before you go any further, start by deciding what you want from the car. you want a better ride? better handling? performance? street, street/strip?
once you decide on what you want, then we can help you with a cogent plan of action.
i assume that you are wanting to improve the handling and performance of the car, so the very first thing you must do is set the foundation, and get it right. a stiff chassis will magnify any modifications you make across the board.
to that end you want to start with sub frame connectors, jacking rails, and an extreme matrix brace. this will not only tie the sub frames together, but they will also stiffen the rocker panel, and tie the two together and this will stiffen the chassis up quite nicely.
