3.8 W/auto :(
you dont say what year, but if it is the AOD, then much has been written about them. if it is the C4 or C5, then again much has been written about them as well.
any of the three are worth keeping, my favorites in order, depending on usage, are;
AOD- street or street/strip
C4- any application
C5- street.
I believe it's a 83. Only paying 500 for it to start lol so if the auto is good maybe just a shift kit then. Mostly just want to Make it handle good. Not so much about power yet...
don't waste the time or money with a shift kit. You'll need to install a trans cooler or you can burn up the trans. If you want it to handle better than stock. put a set of gabriel or kyb replacement shocks and repalce the stock rubber sway bar end link bushings with poly ones. The best way to improve handling is with a good set of tires.
ok, before you go any further, start by deciding what you want from the car. you want a better ride? better handling? performance? street, street/strip?
once you decide on what you want, then we can help you with a cogent plan of action.
i assume that you are wanting to improve the handling and performance of the car, so the very first thing you must do is set the foundation, and get it right. a stiff chassis will magnify any modifications you make across the board.
to that end you want to start with sub frame connectors, jacking rails, and an extreme matrix brace. this will not only tie the sub frames together, but they will also stiffen the rocker panel, and tie the two together and this will stiffen the chassis up quite nicely.
So add frame conecter. But that still doesn't help the tranny issues. I want to be able to shift it my self. I just like to have the controll. So is it worth making the auto work or swap for 5 speed
I don't know that's why I was asking. I don't on keeping the engine forever. Just wasn't sure if they were like a turbo350 and will handle it. So 5speed would be a better choice long term. But which is cherper for now
well first you have to determine which transmission you have, the door tag will help you with that. if you have the C4 or C5, then you can shift to your hearts content with no issues. if you have the AOD however, then you need to change the valve body to one from either lentech or silver fox. they both have valve bodies that change the shift pattern of the AOD from p-r-n-od-3-1 to p-r-n-3/od-2-1. this way you dont have to do the AOD "dance" where you start in first gear, shift to third gear, then back to first to hold second gear. strange i know, but that is the way ford designed the trans.
Ok the problem is I don't have the car yet. I will have it as soon friend buy new tires for her truck. So I don't have all this info yet. So sounds like what I need is a c4 tho
