What Happened?!?!?!
Thanks for that! I thought I just needed a nut for the stud on the rear? What size is that? Just pulled into the hardware store parking lot. Lol.
You need a metric nut that fits on the bolts that I listed above. :P
No really... You would find the nuts and bolts at the same places. Hardware store or automotive.
Just call around a little before heading out.
Lol. I figured as much but I thought you were referring to the bolts that held the bracket on the frame and not the nut for the shock stud on the bracket. Nonetheless, I got the bolts and same size nuts.
They're in. Havent gone for a test drive yet though.
I don't think it matters. The washer should be a little bit larger than the face of the nut. Those shocks should only be taking force at one angle (minus a nominal amount of slop) and the bushings should be physically attached to the metal bushing inside of it.
Reactions: JonnyBlazeGT
