It's "errant".
Ok,...I'll ask a question.
1. When painting the car, what is the best "path" to take. In other words, where do you start spraying, and where do you stop?
2. As high as my car is off the ground, I still couldn't get the gun pointed at the bottom of the rockers w/o the air coupling stopping me from tipping the gun up any further. I almost had to tip the gun over to the point of paint coming out the vent on top.
Suggestions?
3. For Acrylic Enamel paint, how long do I wait, and what steps of grit should I use to color sand and buff the bumpers?
4. after having masked the car for primer, can I leave it masked for color in the same stuff?
5. is the 320 grit finish I'm currently blocking the primer with fine enough to top coat?
6. I'm painting my car Orange. Sealers come in 4 primary colors: White, Grey, Buff, and Black. I read that a white sealer would make a brighter color "pop" more than a grey or buff. I've already painted over the small pieces sealed in rattle can grey. What should I use, and will there be a hue difference if I seal the body and big parts in white?
7. The recess for the tail lights, and the grille mesh in the G gills are gonna be painted a contrasting flat/matte black. Can I rattle can those areas first, and then mask them off prior to the orange, (less masking) and do I have to worry about the overspray from the rattle can causing a paint reaction when the orange is sprayed over the overspray?
8. Is there such a thing as an "affordable" full face respirator, and what do you use personally?
(I'm still finding my glasses a little compromised from exposure to the priming regimen, I'm sure it'll be really bad when I start spraying sticky acrylic enamel.)
9 When building a booth it seems far less costly to just place filters at the front wall high, and fans sucking at the back wall low. That'll create a "negative pressure" and want to suck junk in past the cracks. But if I seal it well, and stop the fans when I walk out of the booth to refill the gun/leave,....is that gonna work? or do I have to positively pressurize the thing?
10. The compressor turns on in the middle of a recoat sometimes. Is it best to keep spraying when it kicks on, or should I wait till it fills, or does it matter?
There go.......painting 101 questions.
I'll save the other 10 for next time.
