01 Mustang Gt Rebuilt Engine Knock
hunterd99
Took the engine out at 115K due to a spun bearing.
Had the block bored .020 over and went with a rebuild kit provided from my machine shop which included bearings, rods, pistons, rings, and all of the gaskets and seals.
I put the engine back together started it up, runs great. When the car gets up to temp, this noise in the video starts happening.
Definitely worse under a load. Yes, I have hooked up a mechanical gauge to check oil pressure and the pressure is good.
I was leaning towards spark knock because of bad fuel but I filled it up with 93 and the noise persists. New coils.
It just threw a code for the 02 sensor on #2 bank also and a code for EGR valve but I removed it so that's why there's a code for that. Would the EGR cause this or is this a deeper issue?
Thank you
View: https://youtu.be/qG_KAxUbQnM
The EGR angle is intriguing. It does sound a lot like detonation but the circumstances (light load) seem odd. One thing that might contribute to light-throttle detonation is no EGR, especially if the tune expects it.
Exhaust gas is inert and when it's introduced into the combustion chamber it tends to cool the peak combustion temps (ultimate goal is to reduce the temps so the oxides of nitrogen -- NOx -- don't form) which can also help reduce the engine's tendency to see detonation.
Perhaps you can try reconnecting the EGR and the vent and vac solenoids (etc) to see if the situation improves. If this isn't feasible, maybe look into the tune and reducing the throttle tip-in spark advance.
I don't think the EGR is causing this though. It could be but I don't think it is. I was starting to think either my timing is out of place or my timing tensioners aren't doing their jobs
+1 on what Trinity_GT said. EGR is inert. The symptom of excessive EGR flow is poor idle and lack of power.
HOW did you time the motor?
When you released the clips on the timing tensioners, how tight was the chain? How much did the plunger move?
Do you have pictures of the timing chain marks when the job was finished?
I didn't take any pictures. But I set it tonTDC with the timing sit at 6 o clock. Then I lined up the dots on the gears and the chain on both sides and released the tensioners. So at TDC my dot on my driver side gear is basically at 12 o clock and my passenger gear is at 10 o clock
Some pictures
After removing the cover. Does my timing seem right? My tensioners seem perfectly fine
It would have help to have taken the pictures with the crank trigger wheel removed.
I just recently completed a timing set replacement on a 2005 3V 5.4 F-150. During the job when I was installing the the right hand timing chain, the left hand timing chain slipped by one tooth. The problem was found during the double check and corrected.
I can tell you from absolute first hand experience that it was NOT possible to "look" at the cam and tell that the cam was off by one tooth. When looked at from a distance the O'Clock position of the cam appeared the same to me. What I'm trying to say is that the O'Clock position is fine for a gross error check or an initial starting position but it's not good enough for the end product.
The ONLY thing that matters is if the marked chain links match up with the dots.
I don't see a marked link or a different color link on the pictures. Did you fold the chains in half and mark the mid-points or does the set have different color links already on it? If so, it's possible to turn the motor over by hand and sooner or later the marked link will line up with the cam dot. Then it's a simple matter to see which tooth is engaged on the crank.
An option is to count the links in both directions from the cam dot. An engine that is correctly time will have the same number of teeth to the crank 6 O'Clock position.
