is that the thick cable on the underside? I looked at it but nothing seemed wrong with it.Have you looked at the linkage and cable on the side of the transmission? You may need a helpful hand, flashlight, and another set of eyes.
Yep that's right. it feels like the button is stuck on the handle. I can push it in a quarter of the way or so before it is 'stuck'So with the engine running and your foot on the brake, you cannot shift out of park?
I think it might be that, The shifter works after I removed the shift interlock cable (looks like a bicycle wire) so it's in that area at least. Either the interlock itself or the terminals on the switch.I had that problem a few times. I ended up putting different terminals on the wires going to the brake actuator switch behind the brake pedal
Ever had the key get stuck in the ignition? It works fine and turns the car on, it can go into accessory. But the key won't come out. Its not the ignition cyclinder. Tried two no ones and nada
Hm well my lights are working... so I guess it's not the switch. Probably the interlock thenI figured out cause noticed brake lights didn't come on. Key, had problems with on other Fords... can't remember exactly cause. Thinking steering wheel locked, turn to relieve pressure, or linkage wasn't quite in park.
