Help !!!! 65 With No Plug Spark
Darrel
I just put in a new complete front to rear Ron Frances Harness in my 65 200 6cyl. First time ever doing this . Ok motor will turn over but no spark ? I have replaced coil, points , set timing, I have no idea what to do next . Any help would be very appreciated. Car was running before I messed with it.
Thanks so much for the reply , Now how do you do this ? I am a newbie to this stuff. Thanks Again
I also looked at the coil and I have one wire going from the - side of the coil to the distributor and there are three wires coming from the ignition switch to the + side . Online it shows only one wire to each side could this be the cause ?
Sorry for the delayed response. You will need to look at your wiring diagram to determine exactly where those wires go. There are multiple wires on the + side of my ignition coil. One is the lead for my Tach though and you may not have that. Which harness did you get?
