Progress Thread My Kenne Bell Twin Screw'd Foxbody thread, (new addition to the family)
What do you guys think about my shaft? Do I need to shorten it?
I had my shaft shortened so the seal rode on the clean part of the shaft.
I marked where the seal sat...then removed the shaft and marked where the seal used to ride with the SRA.
I then measured and had a driveshaft shop cut it down and balance it. A lot of people clean the shaft with emery cloth and leave it alone.
The IRS moves around way less than a SRA so it might be alright. Too close for my comfort though. I haven't had any issues with wheel hop or weird vibrations. My rear and driveshaft have been in cars of mine for a lot of years and daily driven for a while.
I think the rule of thumb is somewhere between 1/2 inch to 3/4 inch to allow for drive train movement. I'll see if I can get a pic of mine when I get home.
I like it looks good.
To make life easier on you, eliminate idle compressor surge (caused by a surging idle the blower will make it worse) use a small hand vacuum pump and hold the bypass open. Trust me when I say this is much easier when your first starting out...
You can also use this to hold the bypass open on the first few drives, this way you build little to no boost and don't have to worry about that part of the tune until you are ready.
IIRC the by-pass valve on these is normally open and vac causes it to close and force the air charge through the motor.
If that's correct, the vac line just has to be pulled.
It's been a little while since I looked at it.
Hmm... if that's the case where do you get the vacuum signal from during wot/boost conditions?
FWIW. All the bypass valves I have used are vacuum open.
I can't explain in great detail but these mini cooper type bypass valves are vacuum closed. At idle and cruise (low vacuum) the valve is open to recirculate air. When you step on the gas the valve closes.
Yes that's vacuum open it takes vacuum to open the valve. (Normally closed vacuum open)
I use the mini cooper bypass valve on my homemade setup. The newer valves will start to close with low vacuum 3-5"hg, but higher vacuum causes them to open. 8-10hg and greater.
So a vacuum pump will hold it open.
Reactions: FoxMustangLvr
Couple of setbacks today. O-ring that came with the TB is way too big. Also my AFM power pipe coupling won't fit over the throttle body so I need to order a 4" to 3.5" adapter coupling.
Ya know... that's no small thing to miss. The o-ring, I mean. Who checks this stuff?
Bummer on the PP. Are you sure you want to use it?
