Sounds like a planHmm, leave the canister in place at least. I just put one back on my car after dealing with gas smells for years. Just leave the line from the canister to the intake tucked away in the fender.
I'll use it until I get me a 4" PPYa know... that's no small thing to miss. The o-ring, I mean. Who checks this stuff?
Bummer on the PP. Are you sure you want to use it?
I found out that the PiMp ECU needs to see both vacuum and boost so I moved that line to the discharge side which opens a port in the inlet for the charcoal canister. All is good now.I PUT a canister back on my 85. It got rid of 95% of the gas fumes after driving it. Don't just plug the vent line...your tank will not like that. I sounds like a shaken up soda when you open the cap to fill up with gas and the tank crunches and groans because it's not venting. I just have the vent to the canister and the canister is open to the atmosphere.
Thanks Steve I totally forgot about that. I'll leave it disabled for now and dump the line in the fender for now until I figure it out with you. I've had no charcoal canisters in previous foxs and wasn't bothered by fumes (didn't notice them honestly)The charcoal canister purge valve will not work unless you repin the pimp to open it...
Don't hook the canister up to the manifold vacuum it will cause tuning issues.
If you want to use it (will use an output for the valve and will need to be linked to a table for fuel trim) it can be done but will complicate the tune. Pm for details.
Cool LED light for working on your car but WOW check out that clean Fox!
View: https://www.youtube.com/watch?v=MsJ1uqQfrAo&feature=youtu.be/?SRCCODE=1EM4804&trk_msg=EQKM9920BH8KFDLBT1QFB4TAAK&trk_contact=DQOCU5HL2PGVFKDMBRF2DM4K3O&trk_sid=FFQ89TP8A51JG408DR38FOHRA0&utm_source=Listrak&utm_medium=Email&utm_term=https%3a%2f%2fwww.youtube.com%2fwatch%3fv%3dMsJ1uqQfrAo%26feature%3dyoutu.be%2f%3fSRCCODE%3d1EM4804&utm_campaign=1EM4804&utm_content=1EM4804
Ok, how hard is it to get the correct size o-ring from American Muscle? Maybe the third time will be when they get it right!
Both o-rings were packaged for a 90mm TB but clearly are way too big to fit the groove. This time AM said they'll test fit the o-ring before shipping it out to me. Genius! The mistake begins with Accufab packaging their product with the incorrect size o-ring and AM being to lazy to test fit. I will hurry up and wait, again.
This was the second o-ring that was packaged wrong. I got my Accufab 90mm TB from AM, went to install it and the o-ring labeled for a 90mm TB was too big. I told AM about this and that I think it was packaged incorrectly from Accufab and passed along to me. So what did they do? They raided another Accufab 90mm TB for it's o-ring labeled correctly for a 90mm TB and rushed it out to me. Same problem again.If i were AM, I wouldn't think to test fit them either... until after the first one that went out was wrong.![]()
So now they are finally going to test fit it before sending it out to me. My point is that they should've done this when I originally brought this up, it only takes a few extra seconds to double check fitment.Sure, i want to see how complete there base tunes are anyway.On another note, Shannon from Stinger Performance was quick with getting me a new base tune for a V8 with boost. @a91what , do you want to take a look at the tune file for me before I load it up and start plugging my info in?
This was the second o-ring that was packaged wrong. I got my Accufab 90mm TB from AM, went to install it and the o-ring labeled for a 90mm TB was too big. I told AM about this and that I think it was packaged incorrectly from Accufab and passed along to me. So what did they do? They raided another Accufab 90mm TB for it's o-ring labeled correctly for a 90mm TB and rushed it out to me. Same problem again.So now they are finally going to test fit it before sending it out to me. My point is that they should've done this when I originally brought this up, it only takes a few extra seconds to double check fitment.
