My hood scoop is not very glossy and kinda orange peely (just sitting on the dusty hood atm). Gonna have to try some super fine grit on it, and polish it. Still havent tweaked the front bumper into place yet, but I only have so much time with the newborn. We are slowly getting there fellas!
Your hood scoop isn't very glossy for the same reason it's highly susceptible to solvents. It's lacquer.
This is gonna sound waay harder than it will really be because you've got a small piece, it is already painted nicely, and that paint is new and soft.
Get some 800 and some some 1500 grit paper. (or better yet, you can even get a sanding block in those grits from AZ.)
Wetsand the thing w/ 800 first till you see a flat surface, wiping it dry regularly to check what it looks like dry. You'll know what I'm talking about immediately after you dry it to check. Watch the color of the water as you sand,..it'll also be a clue as to how much you're sanding off, as it'll start turning red if/when you cut through the clear coat. The 1500 gets rid of the sandscratch carnage that was left from the 800, so you only need to go over the thing a couple of times w/ that.
Then....get some #2 rated rubbing compound and hand rub that thing like DanielSan....(sanda da floor,...go,..this way w/ a right hand, den go this way w/a left hand.)If you really want to get it looking good, get the #1 finishing polish, and that'll get rid of the swirl marks that the #2 creates..
Wipe it off.....you'll get a gloss that shines better than the rest of the car real quick. Lather, rinse, repeat till that btch looks like a Steinway. And you'll see why the words "hand rubbed lacquer" were the standard for a show quality paint job for 40 years..
