Post pics of how your foxbody currently sits
460 cui big block with 1986 heads ports cleaned up, dual cold air intake, 4 barrel holly carb, recurved distributor msd wires coil and msd 6AL ignition,ford motor sport cam, double roller timing chain,deep sump oil pan, aluminum water pump, harmonic balancer, bigger fuel pump,digital wideband,headers with 3 inch dual exhaust 120 hp wet nitrous set up with detached fuel system,larger radiator, battery in trunk
transmission is a rebuilt c6 with shift kit and 2800 stall convertor with large cooler,
rear end is 3.73 with tightened posi,
sknny tires and rear micky thompsons and track slicks
weld rims.
Well that had to be a fun moment!!! I never got that much air in first lol!
What did it run?
Couldn't get it to 60 like it was the power comes on much sooner. Mph was like 133 though. All said and done it should go like 137-140 . Now we have something to work with data wise
