460 cui big block with 1986 heads ports cleaned up, dual cold air intake, 4 barrel holly carb, recurved distributor msd wires coil and msd 6AL ignition,ford motor sport cam, double roller timing chain,deep sump oil pan, aluminum water pump, harmonic balancer, bigger fuel pump,digital wideband,headers with 3 inch dual exhaust 120 hp wet nitrous set up with detached fuel system,larger radiator, battery in trunk
transmission is a rebuilt c6 with shift kit and 2800 stall convertor with large cooler,
rear end is 3.73 with tightened posi,
sknny tires and rear micky thompsons and track slicks
weld rims.
weld rims.
