Aftermarket headlights....well..suck. They don't project the beam correctly, not that the stockers were much better. Those headlights were never factory, so you are relying on the supposed ability of a company to properly design and validate the reflector, and then build them in china with very loose QC and meet strict roadway standards that OEM's spend millions on design to achieve. So you need to take their abilty to project with a grain of salt.
However, part of the issue coule be electrical as well. The intensity of the bulb depends on the voltage it receives and this all depends on the wiring feeding it and the grounds. A good solution is to rewire the headlights so that the original wiring triggers a relay that is feeding direct voltage from the battery and a good ground. This will ensure the brightest beam from the bulb.
