Need To Get My Injectors Serviced
ace305
171
17
28
I purchased a set of 36# injectors used. I would like to get them professionally look over. this is for a 2.1 KB build. any suggestions to contact?
thanks
will these BOSCH 0280155868 fit my 2001 with Kenne Bell?
I have had good experience using InjectorRX.com. Once cleaned and flow tested they are as good as new.
I almost always have the injectors serviced during a major motor project ESPECIALLY when I use (as I often do) a replacement salvage yard motor. It just seems like cheap insurance to me.
thanks
I don't think those injectors are going to be large enough without an accompanying Fuel Management Unit (FMU).
On a Windsor block, 42# are barely adequate over the top of a healthy build.
How much boost do you plan to run and how is the tuning being accomplished?
