Build Thread 1978 King Cobra Build
Vic1978
94
52
38
E17513A8-6B77-47C1-AFF5-694DA47DBC24.webp 6219494E-D6B3-4FA6-8891-8B8B63AC164F.webp 845B7399-9E60-4554-9E18-B446854F0A7C.webp 33552B8F-CA5F-4724-AEC1-1A477E1BA5C6.webp FF887DA7-987C-49D3-ACB0-BB2C53A3C7DD.webp 72B72614-238B-4410-8E83-3A9F9E71D26F.webp BE070379-F260-4B0F-BB54-FA18D5D72AC1.webp FE551B4C-C296-4444-A491-1F494F354A8B.webp A039CCBA-C177-4A39-8738-E64DD62E4629.webp 089ED096-0DAC-45F5-AE5C-1ACF4404B790.webp
In really rough shape. 1978 King Cobra, 302, auto transmission.
Sent the engine for a rebuild. Stock short block rebuild with KB pistons, AFR 165 aluminum heads, Comp Cams XE268H Cam, roller tip rockers, Edelbrock alum intake, Edelbrock 600 carb.
Looking to get a little more than stock. After some research, this combination seemed ok.
Reactions: Manoah and LILCBRA
9EC047C1-EBFC-4EFA-BC16-F00BD9D008E6.webp 98A9C30E-47E5-4A8E-8361-A56E8E0D5D41.webp F2422D04-9154-48DC-95AD-F3FAE5EC2332.webp 773A1FF3-3AE2-48AD-AF13-6040302B360C.webp EA2FAE8E-F097-49CC-8F6F-7B5424B64E68.webp Interior is really rough. Bought the stock seat covers and had them installed onto the seats. Haven’t installed them back in car yet. I need to work on replacing the heater core that I bought and needs replaced.
Also bought the center console lid, dash brushed aluminum inserts and another good used dash pad.
Going to send these rims to get polished and clear coated. The 13x5’s I bought on eBay, the 13x8.5(I believe) I’ve had for about 30 years, saved in my garage.
The chrome wheels I got a deal on and going to try to install. They are 17x10 r 7055EA17-AAE6-4854-B18B-88514BCBD0B4.webp 1C298BE9-A014-4CA1-8320-10C8D2FC19B4.webp A577B708-CE16-4617-8EA4-696FCC3832F0.webp ears and 17x9 fronts. I’ll need to massage them in there with spacers (fronts) and smaller tires and they might fit.
Reactions: LILCBRA
Going to send these slotted mag rims to get polished and clear coated. The 13x5’s I bought on eBay, the 13x8.5(I believe) I’ve had for about 30 years, saved in my garage.
The chrome wheels I got a deal on and going to try to install. They are 17x10 rears and 17x9 fronts. I’ll need to massage them in there with spacers (fronts) and smaller tires and they might fit.
Reactions: LILCBRA
Im trying to get an ok little runner out of it. I bought it in running condition but the engine needed help. Didn’t want to spend this money now but i just want to get it running.
Thank you Jim, I hope so. I have two six speed projects, had a chance to get a Cobra with a manual trans and passed on it because I was looking for the auto.
Had to pull off the dash board to get to the heater core. Filthy. Replaced the heater core and had to check to make sure the AC Evaperator Core next to it was good. There is a dark spot on the lower corner of the Evaperator Core and the plastic below it has a hole. AC shop checked it, no leaks and a put it back together. Not completely finished with it but almost finished with the dash.
Reactions: Manoah
