Please help 88 5.0 mustang gt.
You need to dump codes to see if the ECU is giving you a code 22 with it plugged in. Could be a bad sensor
Ok so I thought I had everything worked out. Car was purring and running like a new car after replacing map sensor. Left track last night and idle started going down then up and with lights on car constantly cuts off when I stop. Battery good and alternator charging, any ideas?
back of head/intake to firewall ground [braided wire strap]
battery negative has a few tails on it make sure one of them runs over to the engine somewhere
check the ecu ground at the battery, it should ground with a small white connector that plugs into the negative cable harness [not sure about your year the 91 i have has this]
I will check on these and let you know. Everytime I have lights on and stop car cuts off.
