Ok so I thought I had everything worked out. Car was purring and running like a new car after replacing map sensor. Left track last night and idle started going down then up and with lights on car constantly cuts off when I stop. Battery good and alternator charging, any ideas?You need to dump codes to see if the ECU is giving you a code 22 with it plugged in. Could be a bad sensor
