Yes it does. On my car I accomplished this by using one of my nitrous throttle switches. When I press the gas, more than 80 percent, the switch sends a ground signal to the WOT cut relay turning the AC compressor off. When I get off the switch AC functions as normal.
I'm confused by your question.
On the pass side fender, under where a MAF would be located, is the WOT relay. When you give er the beans, the relay should interrupt the engagement of the A/C compressor and temporarily turn it off. IIRC, the location the vents blow changes as well. If you have it on Vent, it will go to the floor/defrost.
The WOT relay will do it on it's own in stock trim. I run Mega Squirt so my car is a little different. Sorry for the confusion.
A little cooling shot never hurt anybody.No, I use a nitrous switch to trigger the ac cut off. My car doesn't use the factory ECU. Didn't know if you needed a " work around " for ac cut off.
My car is turbo now so no need for the Nos. I could've used an output on my MS but I want to use them for other things....like water meth injection.
Why can't you use one on a tb? Seems like it would be easier.
I would think there would be a way to manipulate the idle air control valve.
joe
No clue. I would only think it would if the voltage parameters were out of range??? I think the IAC sees a ground to make it function, but I could be way off on that. You could check a schematic and see. If it did, you could put a diode in the ground signal wire to keep from back feeding in the ecu, then splice it a ground wire with your flip switch.Might that trigger CEL?
Megasquirt can be modified to work the WOT relay. Mine does now.The WOT relay will do it on it's own in stock trim. I run Mega Squirt so my car is a little different. Sorry for the confusion.
