- Jul 7, 2005
- 1,563
- 1,197
- 164
Update:
I got both of my parts in the mail today RPi and Serial to USB adapter. I went out and tested the new cable, and it still powers ON the RPi with the power supply off - FAILED TEST. I then pulled out the new RPi, pulling in all the connections again, and it still powers ON the RPi - FAILED TEST.
So I am for some reason have an issue when you connect the MS ECU to the RPi with the Power Supply connected it can boot-up still??????
@jrichker do you have any input on my above issue? I am out of thoughts other than putting a diode on the micro USB cable that comes from the power converter in the power supply to protect it from somehow pulling power to bootup? If you think that will work what diode do you recommend?
