Electrical 93 5.0. Anyone know if i can remove this?
James V
5 Year Member
Feb 26, 2017
409
144
63
Connecticut
I'm in the process of installing new E fans. The black relay on the left with the purple, yellow, black, and red wires is from the old fans. He had the red wire with the yellow connector hooked up to the circuit breaker on the right. Can I remove all of it? And if not what do I hook the red wire too? Basically what I'm asking is was the circuit breaker from the factory or can I take it off as it was part of the old kit?
There should be a black wire that runs from that screw with the black connector to the battery, it is one of 4 ground wires that is essential to the computer/efi system
battery to block, not the timing cover, not an accessory bracket, the engine block.
drivers side rear of head to the fire wall
ground wire from the injector harness to the intake or head. This wire may be orange, not sure,
And the wire from the negative battery cable to the screw previously mentioned.
Reactions: James V
Thanks for the info!
