Build Thread Enola- Finishing touches
Oh my promaxx180cc heads came in as well, let's unbox em.
Great stuff.
If I were you, I 'd have my machinist do a full disassemble and check for valve concentricty, and validate the installed height and spring loads of the valves. Often they are out, even on good heads.
Once thats done, re-prussian blue and bed in the valves to the inserts.
Common issues are the pushrod clearance and port positions. They don't have to be port matched if the intkae holes are bigger than your intake, and the exhaust holes are smaller than your headers. Engines make better power if the port mismatch goes that way.
The castings are good, but they do need to be checked. There is no such thing as a bolt on an ready to run set of bought in heads.
Reactions: General karthief
OK so i am still waiting to hear something about my block, but while i wait i decided to go ahead and price 2 differing builds... the first is the 351 the second is the 393....
I now have the heads to support either variant of the engine, my blower moves more CFM than either can use = blower will make boost....
I have to buy pistons/rings for both
-the cost between the two is very similar, within $200.. both aiming for a 9.5 compression ratio for the boost.
What direction should i lean? i cant decide.
351 OR 393
  • Useful
Reactions: KZGUNS and jrichker
351 OR 393
The first question you should find an answer for is how are you going to communicate all that power to the ground? Just spinning the tires without quickly going forward is a useless waste of rubber and effort.
Car already has full suspension underneath it with subframe connectors, team z upper and lower control arms adjustable rear shocks ect... it was able to plant all the power from the 306cid +12psi.... so im hoping the 393 +5psi will plant as well.
Reactions: KZGUNS
393 would be bad ass.... but i have heard a lot of people beating the :poo: out of the tried and true 351 with no problems.
not sure on the machine process on the stroker with the block but a plus to the 351 is if something were to happen you could probably re use alot of the 351 parts on another run of the mill 351 and not be out all you machine work.
