Engine 1989 turbo mustang
Hi new here. Just pick up a 1989 mustang with a f303 cam with rockers Ford racing aluminum heads cobra intake manifold with turbonetics turned down to around 10 to 12 psi currently running 26lbs injectors seems like I have a lot off wasted fuel. Wondering if I should down size the injectors any help will be appreciated thanks
26 lb injectors?? What color are they?
Using 26 lb injectors with stock 39 PSI pressure won't provide enough fuel for a turbo pushing 10-12 PSI boost. What fuel pressure are you running and what size fuel pimp do you have?
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
HVAC vacuum diagram
Fuse box layout
Not sure it's all what I was told the car had
HVAC vacuum diagram
Fuse box layout
They are blue blue and a Ford brand he said they were cobra it running a stock fuel pump fuel pressure I have no idea haven't put a gauge in yet
