yea - turns out the tool was a bit harder to use than expectedMake sure you took the bolt out and the washer too
If it’s stock replace it . I replace them all with a Powwrbond PB1084ss . You cannot beat them for the money . Made by gates in Australia . Even though you aren’t racing this thing they are sfi approved . Look just like stock but much better quality and the timing marks are laser etched . Last time I went to order a junk ford racing one it didn’t even have timing marks and the rubber was already protruding . I run the neutral balance version of this same balancer on my blown 347 .Got everything out, couple questions:
- should I just replace the HB? A friend is saying just to do it as it can go bad from the removing.
- what order should I reinstall everything? I was guessing tstat first before timing cover, HB, etc.
- I saw a video about performing the first pressure test with plain water, just to not have to mess around with antifreeze. Thoughts?
- should I do a full flush of the block when this is done? I read the 10hrs of drive time then change the oil. Thoughts?
Thanks all
$60 shipped from AA. Is that for real?? Summit is 150!And you can get one at advancedauto parts!
I think thats the one. Turns out it comes in the gasket kit at LMR so ill just replace it. Thank you!Are you talking about the front main seal?
Mustang Front Main Seal (79-95) 5.0/5.8 LRS-6700B - LMR
Replace a leaking 1979-1995 Mustang front main seal with this direct replacement seal from Late Model Restoration!lmr.com
I'm not recommending the one above. Just using it as a reference. As far as that goes I'll let the other guys chime in.
Awesome, thanks for the heads up. I ended up ordering earlier the HB and gaskets. My cover cleaned up pretty well. When I am looking next time, ill drop you a line first. Thanks again!Im from mass i have a timing cover that is sandblasted ready to paint and also believe i have a balancer if you have any interest.
