Progress Thread TxFireman’s Electric Red Coupe refresh
TexasFireman
220
150
64
Beaumont Tx
I haven’t really had a active build thread anywhere in these days of the evil FaceBook world. My other forums I was active on have pretty much gone belly up. After following a few over here I decided to make one.
Here are a couple of the last pictures I took of the car before pulling it apart again lol
Current specs on the car:
93 Electric Red Coupe
Full black OEM interior swap
Full interior car with AC, PS, and LOTS sound deadener. The was originally a 4-cyl car
8.8 with 3.73's w/TA girdle
Eaton locker
31-spline 5 lug axles
Cobra brakes all the way around
All MM braided brake lines
93 Cobra booster
93 Cobra master cylinder
FMS brake Proportioning valve
Hurst line lock
04 GT Steering rack
MM hybrid steering shaft
MM steering rack bushings
Tokico HP Blue shocks/struts
UPR front coilovers
95 spindles
MM caster/camber plates
MM rear height adjustable control arms
98 Cobra rear sway bar
MM full length sub frame connectors
Wolfe torque box plates
Wild Rides battle boxes
Everything welded including torque boxes
It’s been through several drivetrain combos but is currently sitting with an empty engine bay awaiting the newest combo.
New parts about to go in:
SVO R-block 331
All forged bottom end
CNC ported Canfield 194’s
Port matched/pinned TFS-R intake
Vortech V2-Si
Renegade brackets
Anderson Power Bypass
Mondo bypass valve
8” crank pulley
D&D Viper Spec T56
2.66 first gear
.50 OD
McLeod RST twin disc clutch
McLeod billet steel flywheel
DynoTech aluminum driveshaft
PA Performance starter
Stifflers transmission crossmember
It does already have a fuel system. It has a 03 Cobra tank that I modified to accept the Fox filler tube. I cut the section with the filler neck grommet out of a Fox tank and has it welded into the 03 Cobra tank. It has a Fore Innovations billet hat with twin Walbro pumps (8an feed, 6an return), Fore filters, and all PTFE line. I also added -8 rollover valve/vent valve and a section of braided line that runs up behind the bumper with a filter on the end.
I also built my own relay box for my fuel pumps. It’s a redundant system so each pump has two relays. That way if for some reason you lose A relay the pump still continues to run off of the second relay. Relay box is mounted on the side of my battery box
Electrical is already in place as well. Battery box in the truck with cutoff switch mounted to the side of the box. Secure in the trunk for daily use, but I have a spare taillight with a hole in it for track days. That way I can run the rod through the taillight and the “push off” handle. All 2/0 welding cable with positive and negative leads from the battery all the way to the front, and 4-gauge from the alternator straight to the battery. All tinned copper fittings that have been soldered, crimped and sealed with adhesive line shrink wrap.
Reactions: Olivethefet
Nice work, just remember to put a plastic box over the exposed battery cutoff switch posts... Other wise you experience as a fireman could become very personal...
