Electrical Eliminate Starter Solenoid?
RekeHavoc
61
22
18
TN
Have any of you guys with a mini-starter eliminated your fender-mounted starter solenoid? My understanding is that it can be replaced with a standard SPST 30A relay in this scenario.
Are any of you guys using a junction block for power distribution? Are there any issues with cranking amps going through these junction blocks if I were to put batt+, alt and starter power cables on the same post?
Or would it be a better idea to leave all of the starting/charging cables on the starter solenoid and piggyback a junction block for all of the smaller gauge wires?
I'm currently working on a wire tuck trying to clean up as much of the engine bay as possible.
You better get a handle on what kind of wiring you are messing with....
Starter solenoid wiring for 86-91 Mustang
attachments\52294
Starter solenoid wiring 92-93 Mustang or earlier Mustang with upgraded high torque mini starter.
attachments\53216\
Reactions: Gs1987GT
Yes, what you say can be done. Many have done it. Just use a relay to activate the starter relay that is physically located on the starter.
The main issue Is the distribution block. Many of the cheap Amazon/eBay blocks are not robust enough and can break over time.
I plan to do the same with my car but haven’t selected a distribution block yet. I’ve been looking at OEM GM blocks rather than aftermarket. I just don’t trust them
The typical Ford starter solenoid is really a big, multi terminal relay. In the second schematic, it still acts like a relay, but it is sending only a signal to the more typical on starter solenoid and Bendix kick out coil. I cannot see the points sticking and welding with a low battery like the stock set up can.
If you have extra wires that need power, a properly installed distribution block should be safer than trying to get everything on one solenoid terminal.
I think the issues is if you read reviews for many of those cheapo blocks, they break off at the terminal.
I was looking at something like this. I have more trust in these. I just haven’t selected the model I think I can make look ok in the engine bay.
The cheapest distribution block comes off the mid 80s to mid 90s chevy trucks. Its located under a plastic cover on the passenger side of the firewall. They'll handle just about everything you can throw at them.
Reactions: RekeHavoc
Yes, what you say can be done. Many have done it. Just use a relay to activate the starter solenoid that is physically located on the starter.
Now you say you don’t trust them, after you led me to my eBay block! Lol. No issues yet though. Fingers crossed!
It starts here. Just filter through the mish mash, and you’ll get what I did.
Is there any difference in connecting power cables (e.g. electric fans, fuel pump, amplifiers) directly to the battery vs. to the starter solenoid?
If I were to add a junction block, should I connect it directly to the battery or to the starter solenoid? Or does it even matter?
Less connections the better. I ran a wire straight from the battery to the junction block. I did this mainly because I relocated my wiring to behind the fender. My solenoid is still used but also relocated. I have a bunch if aftermarket stuff and needed the extra space the junction block gained. If you locate them behind the fender I recommend using a mega fuse 200 or 250amp on the wire leading from the battery. If that wire is pinched in an accident it will smoke up pretty quick. ( not that we ever want to think about an accident...but they do happen )
It acts like a relay because it is a relay & not a solenoid.
Do any of you guys happen to know what the typical maximum amperage draw would be from the battery (fuel pump, headlights, foglights, wipers, A/C, radio all on)? 75-80A?
