This project stuff never let's me get a clean win. Seems like I always run into something. All the parts came in today so after work I installed the bellhousing, starter, and the tko600. This thing wasn't as heavy as I thought it would be. Didn't need a jack at all.
The first hiccup was the difference between the tko aluminum bellhousing bolts and a t5 bellhousing. The tko browsing uses 7/16- 14 bolts. I found that out after I tried my new bolts and they wouldn't go in by hand. Ran to Home depot at 8:50 ( they close at 9 ). Not a single 7/16 bolt...but you can buy washers though...what a load of crap. They don't even have a spot on the shelf. Left there and headed to O'Riellys. They had the bolts 1.5 inches long. Also, picked up some lock washers.
To get to this point was a little crazy. I had to remove the shifter ( already knew that ) and had to jack the front of the engine up to tilt the rear down a hair. Transmission slid right in.
Like some have posted over the years my tko is hitting the top of the transmission tunnel...right at the first rib after the shifter hole. The instructions for the Stiffler crossmember says to use one of their flat spacers under the trans mount ( takes the place of exhaust hanger do- dad ) and to use the spacers from the tko install kit above the mount. They are 5/8ths thick. There is no way I could get them in so I ditched the flat spacer and bolted everything in.
The main issue is that the TKO is a c☆nt hair from the tunnel. Easy fix with hammer but it means pulling the transmission back out. The bolts supplied with the spacers are too long. I had to add washers to keep from running out of threads on the bolts.
After looking at all this junk I glance up at where the speedo gear is supposed to go in the trans....the bolt is so long that there's no way it won't be in the way.
I slid out from under the car and decided to let it rest. Tomorrow I've got to make another bolt run to grab shorter bolts. I'll also swing past HF for a magnetic base angle finder to set my driveline angle. I could always measure from the line across the crossmember bolt holes and down to the mounting point of the mount...then measure both transmissions from output shaft to the base of the trans mount pad. Measure the height of the mount and hanger, do some quick math, and figure out the exact height needed to put the driveshaft at the same height as the t5. I should've measured down from the tunn to the output shaft before I removed it but I'm stupid like that sometimes.
Dude, you don't know how im reading all of this saying to myself " been there, done that"...if anybody can, I can literally say I feel your pain.
7/16" bolts are automotive only..thats why the home depots of the world don't stock them.
They do have mag base angle finders though....just bought mine last week in order to determine that my pinion had twisted to 20 degrees.
I had that 4l80 in/out 4 times between test fitting, and fixing the fck ups..You may as well suck it up, remove the thing and properly clearance the tunnel, and be done with it or risk some rattle, or vibration that makes noise due to the contact.
I clearanced it this morning. Taking the trans back out was too easy not to get that metal moved. It looks a whole lot better now. My neighbors loved it at 9 am this morning.
Reactions: 2 users
I think I covered the bolts in my build thread,shoulda' checked it out ;) I have room between my trans and tunnel,but there's no way I could use the Stiffler kit with their spacer. Wonder if you could slide hammer the tunnel,would save trans removal.
No way to slide hammer my tunnel. There's another piece above it...and the interior.
How do ya think I found the right size for the bolts ? :nice:
Exhaust is hanging under the car to the mufflers. They'd be on now but the tailpipes and muffler pipes are the same size. This means I need to cut the tailpipes and adapt them to the mufflers. The Kooks resonators are now gone.
Got the exhaust on the car....everything except the clamps. Had to cut 2.75 inches off the tailpipes near the muffler connection. Chopped some 2.5 inch exhaust pipes down to 7 inches long. Got the job done. No pics yet. I want to pull the stainless parts off and polish it up. Also, want to paint the raw steel adapters.
The coilovers went on today. No big issues. For the record....Strange coilovers do fit OEM Spectrum struts very well. The coilover sleeve measures 2.2 inches inside.
There is a very small amount of play...the thickness of masking tape.
The top cap has 4 tack welds. Popped them of with a chisel and hammer. Painted them with semi gloss black engine enamel...perfect match.
Found some bump stops at O'Riellys in stock. Had to trim a ring around the foam thingy and cut a 45 degree angle at the bottom opening to get it over the strut shaft. Fit very well. The MM coilovers are the only ones I've seen with bump stops. I like the idea. The strange coilover top piece looked like it was made for one.
One last little time bit. The piece that cover the needle bearing assembly was a little tight on the top of the strut. I sanded the strut down a little with some 80 grit followed by a red scotch bright pad. Now it slides on and off with no fear of getting stuck.
For one time in my life I didn't get antiseize all over everything aincluding myself. Thats a win in my book. I did have to relocate my brake hose brackets...but that was easy using existing holes. Not really satisfied with how my brake lines look but I'll make new ones at a later date.
Reactions: 1 users
Here's the finished product before I put them on the car.
I used peanut butter ( high temp disc brake bearing grease ) on the needle bearings and races.
They came out good but I may have to up my spring rate. These are 170lbs. For the weight of my front end I should probably have 225lbs on there. Not a huge deal...Summit brand springs are less than 45 bucks a piece. We shall see.
Reactions: 2 users
I agree, by the time you load the front end weight on the strut, i think the rubber thing will be smashed.
Adjusted 5 inches from the bottom it'll take 4 inches. The spring rungs are almost 1 inch apart. We'll see what happens. The good thing about foam bump stops is they always can be trimmed down.
This was before I turned my steering wheel lock to lock....squirting PS fluid all the way to my tool box. It came out of the breather hole in the cap. Did find a small leak at the power steering pressure line at the rack. I'll investigate further when I get home.
I've been trying to find an explorer oil filter 90° adapter for a few days. Guess I'll have to hit up the local junk yard and attempt to score.
Reactions: 1 users
Your brake rotors are on the wrong sides.
Put Dusty on an IV last night. This is how I fill manual transmissions in the easiest cleanest way possible.
I have a ball valve in the hose by the transmission to cut the line off when it gets close to full. No drips and no mess. All the extra fluid goes back in a bottle.
This has worked for me for years. No mess and no fuss. My TKO600 took 2.5 quarts and ended up right below the fill hole
Edit ; after hanging the bottle, with bungee chords or string, I poke a hole in it at its highest point to allow the fluid to flow out. After it gets low enough I cut a bigger section off to make a funnel for the rest of the fluid. Any left over fluid can be drained back into a good bottle. The clear hose, valve and fittings are cheap at hardware stores. Just wanted to give a little more info for those that want to try this method.
  • Useful
Reactions: 4 users
The coilovers ride beautifully so far. Ended up raising them up to 5.5 inches. That actually raised the front about 3/4 inch at the bumper. No more scraping in and out the driveway.
The exhaust sounds a lot better. It's got a deeper tone now and not irritatingly loud.
This was to show the little joy I found today.
If you look real close you can see a very light burnout mark. Just a little light throttle fun.
....that was because.......
The damn flywheel vibrates its arse off. As soon as rpms rise the vibration kicks in like its trying to shake your teeth out. I took a gamble on a Carquest branded one for a 87 to 93 mustang. Its supposed to be 50 ounce balanced. In actuality I have no idea what the balance is on the old billet steel one. I should've just taken it to the machine shop and got it surfaced. Now I have the fine joy of having to remove the transmission again.
This thing will be resurfaced if they can save it. I'd hate to order another one.
...and the saga continues....
...and I see my mistake. SCAT 331 stroker crank...28oz imbalance. Looking at the old flywheel I see where the flywheel has material removed 180° from the 50oz weight...making it 28oz. I never said I was the brightest.
  • Sad
  • Surprised
  • Wow
Reactions: 3 users
These are the sides the paperwork from the manufacturer said to put them on. Seemed weird to me at the time...but they said to do it this way so...
Everything you read will tell you the opposite.
As the rotors turn forward the grooved slots act like wind vanes, to direct air into and under the pads..the way you have them serve no purpose.
